PostGIS 3.5.0alpha2 released supports PG17
'Sandro Santilli'
strk at kbt.io
Mon Jul 8 13:39:24 PDT 2024
On Mon, Jul 08, 2024 at 04:00:48PM -0400, Greg Troxel wrote:
> README.postgis is unclear on what docbook5 xsl is, and given the
> confusion I think it should give a url to the project homepage. Maybe
> I'm the only one unclear.
Is doc/README clearer ?
I agree it is weird for README.postgis to mention docbook but then not
give a section explicitly stating what it is for.
> If the build is configured to build the docs, it should fail if that
> fails. I am ok with docs default off, and off if prereqs not found.
> It seems docbook5 xsl is needed but configure didn't fail what I have
> and decide not to build docs. It tried to build and failed.
Could you please file a ticket for this ?
I agree if you expliclty ask to build docs and it cannot be done you
should get an error, not a silent failure.
> docbook5 may or may not be an ok requirement. I would say it's only
> ok if 95% of packaging systems already have it in what is considered
> their normal release. Basically, a program should only depend on
> things that either come with them (geos) or things that the world
> considers normal and not bleeding edge.
I think we're talking about these:
https://repology.org/project/docbook5-style-xsl/
--strk;
Libre GIS consultant/developer
https://strk.kbt.io/services.html
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20240708/ccbe8497/attachment.sig>
