CMake/MSVC Support
Will Bowers
wbowers314 at gmail.com
Wed Jul 17 11:20:00 PDT 2024
Regina,
Will do. If I submit a PR to your github mirror, will the CI bots pick up
on it? Or does it need to be submitted directly to the repo on osgeo?
I can make a ticket as well if you would like.
On Wed, Jul 17, 2024, 12:00 PM Regina Obe <lr at pcorp.us> wrote:
> Will,
> Thanks for the work thus far. Yes we’d be willing to accept such patches
> assuming it doesn’t break other systems.
> Can you submit a pull request, maybe mark it as WIP if you feel it’s not
> yet in a condition to be accepted. That way we can at least test more
> easily against our various CI bots.
> Thanks,
> Regina
> *From:* Will Bowers <wbowers314 at gmail.com>
> *Sent:* Wednesday, July 17, 2024 12:56 PM
> *To:* Paul Ramsey <pramsey at cleverelephant.ca>
> *Cc:* Regina Obe <lr at pcorp.us>; PostGIS Development Discussion <
> postgis-devel at lists.osgeo.org>
> *Subject:* Re: CMake/MSVC Support
> All,
> Thanks for the info. Like anyone else, I have personal opinions about
> CMake and Meson, but those aren't terribly important right now. There are
> some source-level changes needed to build postgis (and with some of the
> lwgeom source files bundled with postgis, which I assume is some kind of
> fork of lwgeom)... until those changes are made, can't compile on MSVC with
> CMake, Meson, or anything else.
> Here are the changes needed that I have identified so far:
> 1. Macro changes needed with the way math constants in MSVC... need to
> define _USE_MATH_DEFINES first
> 2. Some lwgeom code uses __attribute__ ((format... ))
> 3. There are some predeclarations that trigger compiler error C2375 even
> with /std:c17 because of the way you expose symbols to DLLs in MSVC
> I have put together a patch for (1) and (2) here:
> https://github.com/postgis/postgis/compare/master...ralian:postgis-cmake:msvc_compat
> (3) is going to require a lot more effort and testing. In the meantime,
> would you consider accepting something like this linked change?
> Furthermore, Zimanyi, I will have a look at your CMake scripts and let you
> know if I build anything you might find useful.
> On Wed, Jul 17, 2024 at 10:13 AM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> Tracks right for me. Cmake and postgis has never been a priority, mostly
> because we need to integrate with the postgresql build, and nothing
> happened there for cmake. As Regina mentioned, doing something with meson
> is a more fruitful path to an MSVC build, at this point.
> P
> > On Jul 16, 2024, at 10:40 PM, Regina Obe <lr at pcorp.us> wrote:
> > We had debates about it a long time ago, but none of us were interested
> in putting in the effort to make it work
> > and those that did put in effort dropped a half done patch and left.
> > Even though I’m a windows user, I don’t like using MSVC except when I’m
> forced to so I’m personally not interested in working on CMake just to
> support MSVC.
> > If we go any route, it would be most likely Meson to be in line with
> PostgreSQL proper which does support MSVC in their Meson tooling.
> > But this is my VERY VERY opinionated rehash of history that has passed.
> > Anyone else want to give an alternative view of our CMake past history
> discussions.
> > Thanks,
> > Regina
> > From: Will Bowers <wbowers314 at gmail.com>
> > Sent: Tuesday, July 16, 2024 8:00 PM
> > To: postgis-devel at lists.osgeo.org
> > Subject: CMake/MSVC Support
> > Hello,
> > I was wondering if PostGIS has any current, past, or planned support
> for CMake? I have seen some old forks of PostGIS with some CMake project
> files. I also saw some very old posts talking about building PostGIS with
> CMake, but I don't see anything up to date on the subject.
> > My ultimate goal is to get PostGIS building with MSVC as well.
> > Let me know if you have any resources for me, or if you are interested
> in someone getting this working!
> > Will
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20240717/a45d261a/attachment-0001.htm>
