Proposal: st_remove_irrelevant_points_for_view() and st_remove_small_geometries()
    Sandro Santilli
    strk at kbt.io
    Wed Mar  6 10:17:52 PST 2024
On Wed, Mar 06, 2024 at 03:34:11PM +0100, Sam Peters wrote:
>    Hi Sandro,
>    that's really great to hear! Thank you for the feedback. Two questions:
>    - Should I create one or better two separate tickets/pull requests (for
>    each of the two proposed functions)?
I'd say better to have them separated.
>    - Do you know if it is possible to run the tests and build+view the
>    documentation html pages directly in my postgis github fork? Otherwise I'd
>    likely have to set up the missing pieces locally.
I don't know of any git hoster currently setup to stage-build docs from PR/MR.
It's best if you can build the docs locally. Installing docbook5-xsl,
xmllint and xsltproc should be enough.
--strk;
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20240306/6c1d494a/attachment.sig>
