Aw: Re: Re: Re: Proposal: st_remove_irrelevant_points_for_view() and st_remove_small_geometries()
Sam Peters gluser1357 at gmx.de
Wed Mar 20 10:33:07 PDT 2024
Thank you, that's great. I tried both "make docs" as well as (from doc/) "make html" but run into
  /usr/bin/xsltproc --path .:/postgis-fork/doc [...] \
        --stringparam html.stylesheet style.css \
        --output /postgis-fork/doc/html/postgis-en.html \
        http://cdn.docbook.org/release/xsl/current/xhtml5/docbook.xsl \
        postgis-out.xml
  warning: failed to load external entity "http://cdn.docbook.org/release/xsl/current/xhtml5/docbook.xsl"
  cannot parse http://cdn.docbook.org/release/xsl/current/xhtml5/docbook.xsl
  make: *** [Makefile:415: /postgis-fork/doc/html/postgis-en.html] Error 4
I also tried with "XSLTPROCFLAGS=" for allowing network access (as in docs/Makefile stated), but with no success.
Do you have a hint how to fix this, or is there a logfile to get further details?
Sam
