Re: Aw: Re: Re: Re: Proposal: st_remove_irrelevant_points_for_view() and st_remove_small_geometries()
    Sandro Santilli
    strk at kbt.io
    Thu Mar 21 01:11:45 PDT 2024
Check out docbook5-xsl, if available that's the required one now
On March 20, 2024 6:41:15 PM GMT+01:00, Brian M Hamlin <maplabs at light42.com> wrote:
>on the #osgeolive setup (Ubuntu-Debian-GNU)  there is a apt package called
>  docbook-xsl
>that provides the basic files
>  --Brian M Hamlin    /  MAPLABS  /  OSGeoLive PSC
>On 3/20/24 10:33, Sam Peters wrote:
>> Thank you, that's great. I tried both "make docs" as well as (from doc/) "make html" but run into
>>      /usr/bin/xsltproc --path .:/postgis-fork/doc [...] \
>>          --stringparam html.stylesheet style.css \
>>          --output /postgis-fork/doc/html/postgis-en.html \
>>          http://cdn.docbook.org/release/xsl/current/xhtml5/docbook.xsl \
>>          postgis-out.xml
>>    warning: failed to load external entity "http://cdn.docbook.org/release/xsl/current/xhtml5/docbook.xsl"
>>    cannot parse http://cdn.docbook.org/release/xsl/current/xhtml5/docbook.xsl
>>    make: *** [Makefile:415: /postgis-fork/doc/html/postgis-en.html] Error 4
>>   I also tried with "XSLTPROCFLAGS=" for allowing network access (as in docs/Makefile stated), but with no success.
>> Do you have a hint how to fix this, or is there a logfile to get further details?
>> Sam
Sent from hand-held device with K-9 Mail. Please excuse my brevity.
