Proposal: st_remove_irrelevant_points_for_view() and st_remove_small_geometries()
Regina Obe
lr at pcorp.us
Thu Mar 28 13:55:49 PDT 2024
> Thank you for your feedback! After some workarounds (we had docbook5-xsl
> already installed, but needed also configuring --without-raster, using a local
> copy of the files in http://cdn.docbook.org/release/xsl/current/ and skipping
> some of the existing SQL-based tests) I finally got 'make docs' and 'make
> check' working for me :-)
> Today I created two new branches on my Postgis master fork on Github, and
> for each of them a new OsGeo ticket as enhancement. Please refer to
> https://trac.osgeo.org/postgis/ticket/5705 -
> ST_RemoveIrrelevantPointsForView()
> https://trac.osgeo.org/postgis/ticket/5706 - ST_RemoveSmallParts()
> I tested both new functions with a lot of real data. I also added some SQL-
> based tests cases (/regress/core) and doc files (/doc) with explaining graphics.
> I hope that I didn't make silly mistakes while publishing on Github (it is the first
> contribution to Postgis). So if there is something missing or improvable let me
> know.
> I'd be glad if you can review both functions - and even more if they can make
> it into Postgis :-)
> Sam
I think it would be easier for people to comment if you did a formal pull request against github postgis mirror
Although we don't accept issues on github, we still accept pull requests.
https://github.com/postgis/postgis/pulls
The only reason I say it would help is some in our team like to babble on and on highlighting line numbers and such they don't agree with.
I'm not one of those people, but will make life easier for those and get their attention if they have issues.
Thanks,
Regina
