Implementation of topology-network approach
    Pierre HARDY
    pierre.hardy5 at gmail.com
    Tue Nov 19 06:22:49 PST 2024
Hello PostGIS devs,
It seems that "postgis_topology" extension does not support
topology-network approach.
Here are my sources:
   1. What is topology-network:
   https://www.gaia-gis.it/fossil/libspatialite/wiki?name=topo-intro
   2. Source no1 indicating that Postgis does not support topology-network
   approach:
   https://gis.stackexchange.com/questions/122636/prevent-postgis-topology-from-splitting-edges-on-line-insert
   3. Source no2 indicating that Postgis does not support topology-network
   approach:  https://terragis.net/docs/other/MASTERING_POSTGIS.pdf => p253
"Before we start working with topology, we need to discuss the key concepts
behind the PostGIS topological data model. PostGIS topology implementation
is based on ISO standard 13249 - Information technology - Database
languages - SQL multimedia and application packages - Part 3: Spatial. The
standard name is often abbreviated as ISO SQL/MM. This standard defines two
data models for topology: TopoGeometry and TopoNetwork; PostGIS implements
only the former."
I could verify this by testing on a basic local setup with QGIS and *Postgis
version 3.3*.
I guess this feature was not added since.
I did not found any issues regarding this missing feature.
Is an issue already openned to request this new feature or should I create
one ?
Best regards,
Pierre HARDY
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20241119/8065da41/attachment.htm>
