Implementation of topology-network approach
Sandro Santilli strk at kbt.io
Thu Nov 21 08:51:57 PST 2024
On Wed, Nov 20, 2024 at 10:23:40PM +0100, Pierre HARDY wrote:
> In addition to my previous email (My apologies for double post)
> Point 2 : An alternative would be to bring a small addon to the current
> topology-geometry implemtentation and provide a way for the user to disable
> node creation when 2 lines intersects or 1 line self-intersects... This
> could be an answer to to most uses cases I know, but as long as l know this
> is not promoted by any ISO Standard.
> I do not know if such implementation would be accepted as part of a postgis
> topology extension. What do you think ?
I'd rather not mix Topology-Geometry (what's implemented) and
Network-Topology (what you are after). An implementation of the
standard network functions would best be part of a network extension, IMHO.
--strk;
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20241121/5126e058/attachment-0001.sig>
