PostGIS 3.5.0beta1 is released
Greg Troxel
gdt at lexort.com
Tue Sep 17 06:42:34 PDT 2024
"Regina Obe" <lr at pcorp.us> writes:
> Source: https://download.osgeo.org/postgis/source/postgis-3.5.0beta1.tar.gz
> NEWS: https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.5.0beta1/NEWS
I have locally updated pkgsrc and built and tested, but without sfcgal
(because I haven't gotten to packaging that). NetBSD 10, pg 16,
up-to-date geos and proj.
All built ok.
regresssion tests pass. This is big news, as previously I had
regression failures that I wasn't able to figure out. It turns out my
libm had a bug in remquo, and I have (locally) applied the fix from
FreeBSD. remquo is notoriously tricky; the BSD bug is in code from
Solaris and glibc had a bug too.
I do need to check that regression tests use the just-built copy, not
the installed copy.
I had a note that building with -j failed, but that seems to no longer
be the case.
I find it odd that NEWS is mising news for 3.4 and earlier, but that's
me finding it odd, not a real bug.
Overall I don't see a reason this couldn't be the release, but I don't
know enough to assert that it would be ok.
