[postgis/postgis] Implement ST_Distance via GEOS (#218)
Paul Ramsey
pramsey at cleverelephant.ca
Thu Sep 26 09:07:24 PDT 2024
ST_Distance native to PostGIS has a number of performance benefits that delegating to GEOS will run afoul of
- we can look directly at the data as stored in the database, with no copy, using getPoint_cp, that’s a performance win
- in addition to a copy overhead to get to GEOS memory space, we also pay an object instantiation penalty to construct a GEOSPoint
- for larger and disjoint objects, the native PostGIS implementation has an optimized calculation that gets cost down to O(n log(n)) time
As I note in the ticket, I’m a hard -1 on tossing those advantages, unless I can be shown to be wrong about performance. Better to work the robustness stuff from first principles than to throw away the above.
P
> On Sep 26, 2024, at 3:20 AM, Sandro Santilli <noreply at osgeo.org> wrote:
> Fixes a robustness problem in Topology and doesn't trigger any
> failure in existing teststsuite.
> References #5782 <https://trac.osgeo.org/postgis/ticket/5782>
> View it on OSGeo Git Services: Gitea - Git with a cup of tea <https://git.osgeo.org/gitea/postgis/postgis/pulls/218>.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20240926/6d9a817e/attachment.htm>
