Prevent ST_MapAlgebra segfault specifying rast2 with a single raster
Regina Obe lr at pcorp.us
Sun Sep 29 13:02:23 PDT 2024
> I had a copy-paste error go a little bit more wrong than I'd have expected.
> Patch attached with test, but I don't know if this is the best way/place to fix
> the issue.
Dian,
Thanks for the patch  and ticket -  https://trac.osgeo.org/postgis/ticket/5785
At a glance guarding for case greater than 7 (raster 2 args) in that spot seems good enough to me.
I've back ported thru 3.3.8.
Could probably go to 3.2.  I'll revisit that later.
Thanks,
Regina
