CI on master
Regina Obe lr at pcorp.us
Mon Dec 15 21:17:27 PST 2025
> > On Dec 15, 2025, at 2:57 PM, Regina Obe <lr at pcorp.us> wrote:
> > Looks like it’s failing on GEOS 3.9.  Since we’ve already EOL’d GEOS
> > 3.9  https://libgeos.org/usage/download/ ,
> > should we just up our base GEOS for 3.7 to 3.10?
> Yes, I think that makes sense.
> P
> >  I can swap out that pg14- geos39  for a pg14-geos310 and see if it passes.
> >    From: Paul Ramsey <pramsey at cleverelephant.ca>
> > Sent: Monday, December 15, 2025 4:27 PM
> > To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> > Subject: CI on master
> >  Master has been red on github since this commit to topology
> https://github.com/postgis/postgis/commit/b0dcc8510fd7930752db4e65a9e7
> > f368b63a139c  Komzpa this is yours, can you sort it?
> >  P
Okay I've swapped out pg14/geos3.9 testing with
Pg14/geos 3.10 and it's passing:
https://github.com/postgis/postgis/actions/runs/20257107239/job/58161404254
