Do you use PostGIS BRIN?
Regina Obe lr at pcorp.us
Sat Jan 4 23:53:49 PST 2025
We are thinking of removing BRIN support in PostGIS because it has a serious
bug as discussed here.
https://lists.osgeo.org/pipermail/postgis-devel/2025-January/030457.html
and here - https://trac.osgeo.org/postgis/ticket/5564
that currently causes crashes during Index building.
The two options on the table are:
1) Fix the issue
2) Remove BRIN Support
I'm leaning toward the removal of BRIN support because I see no point
carrying the technical baggage of continuously supporting BRIN and testing
it
if very very few people are using it.  Yes this will be a breaking change
for those that use it.
Thanks,
Regina
