Do you use PostGIS BRIN?
Tomas Vondra tomas at vondra.me
Tue Jan 7 10:50:25 PST 2025
On 1/7/25 18:57, Paul Ramsey wrote:
> Tomas,
> Thanks for taking a run at the BRIN improvement!
>> Understood. Interesting use of BRIN to build indexes quickly, until the
>> regular indexes get built. It probably does not make sense to keep the
>> BRIN indexes after that - the other indexes are likely to be faster, so
>> it'd just allow the planner to make mistakes.
> I think in the context of OSM, the dumps are somewhat spatially
> correlated, so a BRIN index ends up being a quick build with a
> reasonable query performance, particularly for bulk operations.
>> Yeah. I spent some time today looking at this, and it's indeed a bit
>> more complicated than I assumed. There's a couple reasons ...
>> 1) The opclass (I only looked at brin_geometry_inclusion_ops_2d) has
>> opcintype != opckeytype, but the BRIN code does not actually expect (or
>> allow) that. I guess this might be why the opclass overrides the
>> ADD_VALUE function, because the built-in function simply uses the first
>> value as the union, without converting it to box2df.
>> This means we can't get rid of the custom add_value, but AFAICS the
>> _merge is just a simplified variant of it, as it only deals with the
>> box2df summaries.
> I’m wondering if a clean-sheet BRIN might not end up as a nicer
> implementation in the end, especially if we have to define a new opclass
> anyways. Perhaps a 2-d only implementation, which would still be useful
> for people but not require us to cart around all the extra higher-
> dimensional opclasses we got in our initial implementation.
Perhaps. I think it might be best to "clone" brin_inclusion.c and
enhance it to allow opcintype and opckeytype to differ.
>> Yes. I think the main challenge is the case when people installed the
>> new library, but are running with the old definitions. And you're right
>> the best solution would be to "neuter" the "old" functions by adding
>> something like elog(ERROR) into them.
>> But as I wrote above, I'm not aware of a way to modify an opclass
>> (there's ALTER OPERATOR CLASS, but it only allows changing name, owner
>> and schema).
>> So the existing opclass would need to be neutered, and a completely new
>> opclass would need to be added.
> We have hacked the system tables in the past, to sneak opclass fixes in,
> so it’s possible. If we do a new opclass I wonder if we will end up
> carrying the old ones around forever because old installations might
> have existing BRIN indexes that would fail upgrade if we removed the
> opclasses they depend on.
I think you'll need to leave the opclass there as a stub, with the C
functions modified to just ERROR. That'd make the upgrade work, but the
indexes would need to be rebuilt. Not pretty, but I don't think there's
a way around that, even if you decide to remove the BRIN opclasses.
Yeah, hacking the catalogs should be possible. I think you could do a
CREATE FUNCTION for the merge function, and then insert the OID into
pg_amproc. I suppose there might be some dependencies missing, though.
>>> Then later on we could decide to fix it, only fix it for PostGIS
>>> 3.6, or just remove the entrails of BRIN for 3.6 and above.
>> I think adding new functions is not a breaking change - there's the risk
>> people might not have updated the definitions, but in the worst case the
>> those functions would not be called. It's the removal of functions that
>> breaks things.
> I was wondering if the “lowest impact” neutering of BRIN as it exists in
> our stable branches would be to add a check on the values of the
> parallelism GUCs and then elog(ERROR) out if parallelism is turned on.
> Or I guess, since parallel BRIN index build is the actual crashing case,
> neuter things only in the presence of Pg17. Or some combination of the two.
But the parallel build is not the only crashing case - it's an easy way
to hit the issue reliably, but autovacuum can hit it too occasionally.
Yes, it's much less likely (especially on read-mostly systems).
regards
Tomas Vondra
