Do you use PostGIS BRIN?
Paul Ramsey
pramsey at cleverelephant.ca
Tue Jan 7 16:09:08 PST 2025
> On Jan 7, 2025, at 3:56 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> The BRIN API has a lot of good stuff now, which would be good to add to simplify some of the other code (check for empty, check for contained, check for mergeable) I am not sure when in the history of BRIN it was added, do you have a quick feel for that?
I will answer my own question here, the extended BRIN API exists as far back as 11 at least, so “since forever” effectively for our purposes.
https://www.postgresql.org/docs/11/brin-extensibility.html
P
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20250107/db4f5d42/attachment.htm>
