pg_upgrade fails due to lack of dependencies.
Nikhil Shetty
nikhil.dba04 at gmail.com
Mon Jun 30 03:13:58 PDT 2025
Hi All,
We also faced a similar issue during pg_upgrade. Table spatial_ref_sys is
not created and when pg_restore creates a table referring to spatial_ref_sys,
it will error out.
I am upgrading PostgreSQL 13 and PostGIS 3.1.2 TO PostgreSQL 15 and PostGIS
3.4.2
pg_restore: creating TABLE "table1"
pg_restore: while PROCESSING TOC:
pg_restore: from TOC entry 551; 1259 39789310 TABLE table1 db1
pg_restore: error: could not execute query: ERROR: relation
"public.spatial_ref_sys" does not exist
LINE 1: ...LECT proj4text, auth_name, auth_srid, srtext FROM public.spa...
QUERY: SELECT proj4text, auth_name, auth_srid, srtext FROM
WHERE srid = 3857 LIMIT 1
Command was:
CREATE TABLE table1 (
"id1" numeric NOT NULL,
"geom" "public"."geometry"(Geometry,4326),
"geom_3857" "public"."geometry"(Geometry,3857) GENERATED ALWAYS AS ("public"
."st_transform"("public"."st_intersection"("geom", "public"."st_transform"(
"public"."st_tileenvelope"(0, 0, 0), 4326)), 3857)) STORED
IS st_transform function is referring to 'spatial_ref_sys'?.
Thanks,
Nikhil
On Sat, May 17, 2025 at 12:35 AM <lr at pcorp.us> wrote:
> Okay seems like an issue with pg_upgrade frankly that it doesn’t also load
> data in an extension it is restoring from the migrated cluster and how the
> heck it doesn’t even load the structure before any user data seems like
> real bug.
> As mentioned I think the reason we never see this issue is because most
> people use 4326 for geography and that I suspect is hard-coded in our
> system to be never checked against spatial_ref_sys cause it’s the default.
> I’ve ticketed issue here - https://trac.osgeo.org/postgis/ticket/5899
> Paul,
> You think there is some way we could just hard-code longlat srids in
> PostGIS code (or check proj sqlite db now that we require newer proj
> anyway) to address, so there is no dependency with spatial_ref_sys when the
> code is confirming the srid is a longlat projection.
> I’m assuming that’s why it’s checking spatial_ref_sys in the first place
> Only if it can’t find it in our list would it then resort to interrogating
> spatial_ref_sys?
> Thanks,
> Regina
> *From:* Jeevan Chalke <jeevan.chalke at enterprisedb.com>
> *Sent:* Friday, May 16, 2025 6:58 AM
> *To:* lr at pcorp.us
> *Cc:* postgis-devel at lists.osgeo.org
> *Subject:* Re: pg_upgrade fails due to lack of dependencies.
> Thank you, Regina
> You’re right -- this dependency alone doesn't fully resolve the issue.
> We did receive a complaint about missing data in the spatial_ref_sys
> table, with the error:
> ERROR: Cannot find SRID (4283) in spatial_ref_sys.
> By tweaking pg_dump, we managed to dump data for this table *before* any
> user tables accessed it. However, we later encountered a new issue:
> ERROR: relation "public.spatial_ref_sys" does not exist.
> As a PostgreSQL developer, this new error came as a surprise. The table in
> question is part of an extension, and that extension does create it. Upon
> further investigation, I discovered that the issue lies in the sort order
> used by pg_dump when dumping extension and user tables, the order isn't
> always correct. Although pg_dump and pg_restore are generally smart
> enough to account for object dependencies, based on entries in the
> pg_depend catalog, this case seems to expose a gap in that logic.
> Specifically, since both spatial_ref_sys and geography are part of the
> same extension and have a dependency relationship, this relationship is
> *not* reflected in the pg_depend table. If it were, pg_dump would ensure
> the table is dumped before the dependent type, avoiding this issue. This is
> what I’ve suggested as a fix.
> We encountered this problem while using the latest server versions for
> PostgreSQL v11, v13, and v16, along with PostGIS versions 3.2.4 and 3.4.3.
> Thanks
> On Thu, May 15, 2025 at 10:03 PM <lr at pcorp.us> wrote:
> I think we have a tickets somewhere complaining about issues with
> pg_upgrade and geography, but they have always involved just data missing
> in spatial_ref_sys.
> I found this one - https://trac.osgeo.org/postgis/ticket/4405 but these
> cases have always been issues with data not present in spatial_ref_sys
> rather than the table being missing.
> What puzzles me is how this dependency even helps, cause that still
> wouldn’t guarantee data in the spatial_ref_sys table is loaded and
> ultimately I would assume it is checking spatial_ref_sys to make sure 4283
> is a valid longlat projection and will fail if it can’t find it.
> I thought extensions are always created before user tables so should only
> be an issue with the data in them and why spatial_ref_sys doesn’t even
> exist when you load the user table makes no sense.
> I don’t see how putting dependency between geography type and
> spatial_ref_sys would help here and I’ve never seen this particular error
> before.
> I suppose it’s possibly most people just use 4326 which geography doesn’t
> need to verify cause that’s the default srid used for geography when none
> is specified so is probably hard-coded in our system and that might explain
> why we’ve never seen this issue.
> That said, can you give us the output of your postgis versions from your
> PostgreSQL 11 and PostgreSQL 13
> And also what versions of 11 and 13 you are running.
> Thanks,
> Regina
> *Sent:* Thursday, May 15, 2025 9:42 AM
> *To:* postgis-devel at lists.osgeo.org
> PostGIS hackers/developers,
> Does this addition make sense?
> On Wed, May 14, 2025 at 11:07 AM Jeevan Chalke <
> jeevan.chalke at enterprisedb.com> wrote:
> Hello,
> While working with one of our customers, we observed that pg_upgrade is
> failing with PostGIS.
> What is happening is (SQL attached below), the user table "prosch"."MyTab"
> has a column of type "public"."geography", which, in turn, references a
> row in public.spatial_ref_sys. While there is a recorded dependency
> between "procsch"."MyTab" and "public"."geography", no such dependency
> exists between "public"."geography" and public.spatial_ref_sys.
> As a result, while the type "public"."geography" is created before the
> user table, spatial_ref_sys is not. Due to sorting (in pg_dump), the user
> table is dumped before spatial_ref_sys, leading to an error during
> restoration.
> Since PostgreSQL does not maintain dependencies at the row level (and thus
> not for tables containing such rows), the extension itself should
> explicitly define this dependency. This would ensure that
> public.spatial_ref_sys is dumped before the type "public"."geography",
> preventing issues during dump and restore.
> If we manually add the dependency in the source database, pg_upgrade will
> work well. The query to achieve this is:
> INSERT INTO pg_depend VALUES (
> 'pg_catalog.pg_type'::regclass::oid, 'public.geography'::regtype::oid, 0,
> 'pg_catalog.pg_class'::regclass::oid,
> 'public.spatial_ref_sys'::regclass::oid, 0,
> 'n');
> Can this be considered a valid request and added to the extension SQL file
> itself?
> Here is the SQL sequence that yields an error (shared by one of our
> engineers)
> CREATE SCHEMA procsch;
> CREATE TABLE "procsch"."MyTab" (
> "id" bigint,
> "loc" "public"."geography"(Point,4283)
> INSERT INTO procsch.MyTab VALUES (1, ST_GeomFromText('POINT(152.138672
> -30.689888)', 4283));
> $ strings /PATH/bin/pg_dump | grep POSTGIS_spatial
> POSTGIS_spatial_ref_sys
> /PATH/bin/initdb -D /srv/13/data/pg_data
> /PATH11/bin/pg_ctl -D /srv/11/data/pg_data -l logfile stop
> /PATH/bin/pg_upgrade --check --link --old-datadir=/srv/11/data/pg_data
> --new-datadir=/srv/13/data/pg_data --old-bindir=/PATH11/bin
> --new-bindir=/PATH/bin --old-port=5432 --new-port=5434
> # for real, no --check:
> /PATH/bin/pg_upgrade --link --old-datadir=/srv/11/data/pg_data
> And it did blow up with :
> pg_restore: creating TABLE "procsch.MyTab"
> pg_restore: from TOC entry 371; 1259 17425 TABLE MyTab u1
> LINE 21: "loc" "public"."geography"(Point,4283)
> public.spatial_ref_sys WHERE srid = 4283 LIMIT 1
> "id" bigint,
> Thanks
> *Jeevan Chalke*
> *Principal Engineer, Engineering ManagerProduct Development*
> *enterprisedb.com <https://www.enterprisedb.com>*
> *Jeevan Chalke*
> *Jeevan Chalke*
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20250630/2593016b/attachment-0001.htm>
