ERROR: Could not add geog_brin_inclusion_merge to brin_geography_inclusion_ops..null value in column "refobjid" (Re: Do you use PostGIS BRIN?)
Justin Pryzby pryzby at telsasoft.com
Sun Mar 2 11:14:35 PST 2025
Not sure if this the right place to report it, but it seems related to
this thread.
After upgrading to postgresql-17-postgis-3-3.5.2+dfsg-1.pgdg120+1, I got this:
# ALTER EXTENSION postgis UPDATE;
DEBUG:  executing extension script for "postgis" update from version '3.5.0' to 'ANY'
DEBUG:  executing extension script for "postgis" update from version 'ANY' to '3.5.2'
ERROR:  Could not add geog_brin_inclusion_merge to brin_geography_inclusion_ops class: null value in column "refobjid" of relation "pg_depend" violates not-null constraint
CONTEXT:  PL/pgSQL function inline_code_block line 219 at RAISE
Due to:
# SELECT n.oid FROM pg_catalog.pg_opclass AS n WHERE opcname = 'brin_geography_inclusion_ops';
(0 rows)
This is an instance running pg17.4 (having just been upgraded from
17.2), which was pg_upgraded from 16.4 on 2024-10-12 (and previously
from earlier versions).
Also, the data dir was originally initdb'd under centos (7, and probably
earlier versions before that), and most recently migrated to debian
(with the requisite reindex).
In november, it was upgraded from: postgresql-17-postgis 3.4.3+dfsg-2.pgdg120+1
to 3.5.0+dfsg-1.pgdg120+1.  It looks like we have one other instance
which will hit the same problem.
Justin
