Migrating TIGER from Oracle to POSTGIS
Ayorinde O Adesugba (CENSUS/DITD FED)
Ayorinde.O.Adesugba at census.gov
Wed Mar 19 11:18:40 PDT 2025
Census - General
The testsuite is interesting... it is a hinderance cause I dont understand all the moving parts.
The ST_GetFaceGeometry has to change to (varchar, int8) in sqlmm.sql.in
That change has been made, but I am unable to run the tests because it keeps reporting that st_getfacegeometry(character varying, integer) does not exist. It refers to COMMENT ON FUNCTION in topology_comments.sql.
I am not sure what file(s) to change so the comments are fixed.
Thanks,
Ayorinde Adesugba, Special Assistant to ADC,
Spatial Data Systems, DITD
U.S. Census Bureau
O: 301-763-2057 | M: 202-381-8034 | F: 301-763-4710
ayorinde.o.adesugba at census.gov<mailto:ayorinde.o.adesugba at census.gov>
census.gov<http://www.census.gov/> | @uscensusbureau<https://twitter.com/uscensusbureau> | 2020Census.gov<https://2020census.gov>
Connect with us on Social Media<http://www.census.gov/about/contact-us/social_media.html>
Census - General
Sent: Wednesday, March 19, 2025 13:59
To: Ayorinde O Adesugba (CENSUS/DITD FED) <Ayorinde.O.Adesugba at census.gov>
Cc: postgis-devel at lists.osgeo.org <postgis-devel at lists.osgeo.org>
Subject: Re: Migrating TIGER from Oracle to POSTGIS
On Wed, Mar 19, 2025 at 05:44:12PM +0000, Ayorinde O Adesugba (CENSUS/DITD FED) wrote:
> I am facing a more interesting challenge. The topology_comments.sql
> needs to be updated, so that it references int8 (bigint) instead of
> integer for a few functions that need to be updated.
> How do I trigger the comment rebuild.
Comments are generated from the documentation so you should get
get an automated rebuild after editing doc/extras_topology.xml
If you don't, that'd be a bug
See also doc/README in case you want to be more specific about
what you want to build ( spoiler: make -C doc comments )
> I have been stuck on a test for over 2/3 hours cause the comment on
> the function no longer lines up with the new signature for the function.
Isn't PostGIS testsuite great ? :)
Feel free to provide an improvement to the run_test.pl script to catch
those kind of errors and suggest a solution.
--strk;
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20250319/e0d2c829/attachment.htm>
