Migrating TIGER from Oracle to POSTGIS
'Sandro Santilli'
strk at kbt.io
Wed Mar 26 01:39:25 PDT 2025
On Thu, Mar 20, 2025 at 04:42:54PM +0000, Ayorinde O Adesugba (CENSUS/DITD FED) wrote:
> Do you want me to submit a PR, so we can start reviewing and providing feedback?
Yes PR is a good idea. I think I saw a reference to it somewhere,
maybe add a link in this thread for easy reference in the future.
> I also need to discuss how the upgrade path will work out.
I guess the biggest decision to take is whether to support multiple
"formats" of topology schemas or "adapting" any pre-existing topology
to the new format.
At the moment we do have some support for multiple "versions",
in particular we allow for topologies to have a Z value or not.
Supporting multiple datatypes for identifiers would requiring having
to check which version a topology has in before reading and writing
those numbers, which may be not too expensive for the C functions but
worth profiling.
Pro of supporting multiple identifiers size would be to keep topology
small when you don't need large identifiers.
Con is having to maintain multiple code branches.
> I think
> the FACE, EDGE_DATA, NODE and RELATION tables are the 4 that need to be
> updated to allow INT8 IDs, but I maybe overlooking other upgrade items.
Hopefully our testsuite will help with finding this out, although I'm
afraid we don't have tests that use topologies created BEFORE upgrade
- but the testsuite does support pre-upgrade and post-upgrade hooks
being arbitrary SQL files so we could add what's missing.
--strk;
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20250326/30f1d270/attachment.sig>
