Collaboration Interest: AI Guidance for PostGIS in pg-aiguide
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Tue Nov 25 12:00:49 PST 2025
Sounds good. I guess we're at a time when everyone tries to collect their
own library for AGENTS.md :)
A list of things we put together for Kontur's systems, fixing stuff
actually done wrong by LLMs one at a time:
https://github.com/konturio/AGENTS.md/blob/main/AGENTS.raw.md
What I also learned is that while LLM is randomly forgetful about these
spaced repetition helps keep the model's attention on them.
For small lists like ours I made a simple trigram based one,
https://github.com/konturio/AGENTS.md/blob/main/scripts/spaced_repetition.py
LLMs write okay-ish PostGIS SQL. Where they currently totally break is h3,
as the library changed all the function names
on v3 to v4 migration, and there are subtle name differences across
different versions. A skill will be more helpful there.
Maybe we can start SKILL.md in postgis repo so that whoever wants to drop
it into their AI and generate less-wrong, more-blessed code with typical
user error types corrected?
We're already building a cheatsheet but some common mistakes can be listed
to un-learn them at LLMs.
I'll be happy to start and maintain this doc, I'm already doing this anyway
for my use cases.
On Tue, Nov 25, 2025 at 9:50 PM Mat Arye <mat+postgis at tigerdata.com> wrote:
> Hi All,
> We've started a new open-source project at Tiger Data aimed at helping AI
> agents generate higher-quality Postgres code:
> https://github.com/timescale/pg-aiguide
> For broader context, here’s the announcement blog describing the approach
> and motivations:
> https://www.tigerdata.com/blog/we-taught-ai-to-write-real-postgres-code-open-sourced-it
> As part of this work, we're adding guidance modules for major Postgres
> extensions, and PostGIS is at the top of our list. I’m reaching out to ask
> whether anyone from the PostGIS community would be interested in
> collaborating.
> The core idea is to provide “skills” that capture best practices, common
> pitfalls, and domain-specific patterns so that AI agents can make better
> decisions. Here is an example skill:
> https://github.com/timescale/pg-aiguide/blob/main/skills/design-postgres-tables/SKILL.md
> If there’s interest, we’d be happy to set up a call to walk through the
> approach and answer questions.
> Beyond skills, the project also includes semantic search over
> documentation. We currently index Postgres and TimescaleDB docs, and we
> plan to include the PostGIS manual as well. We can handle the processing,
> but wanted to check whether there’s anything unusual about the HTML manual
> that we should be aware of. We’d also appreciate any guidance on which
> versions of the manual are most important to index.
> Thanks for your time, and we’d welcome any feedback or involvement from
> the community.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20251126/59c7654b/attachment-0001.htm>
