Rename "master" branch to "dev" ?
Sandro Santilli strk at kbt.io
Fri Nov 28 11:46:50 PST 2025
In IRC/Matrix we got back to discuss branch naming, due to
CI still having traces of "main" which has been an alias at some point [1]
As the last attempt at getting rid of the "master" name was stuck [2]
due to Regina wanting to see other projects make the strong-move
before bothering [3] and given today nobody would really be using "master"
anymore while some of us use different names (I use "main" locally, Darafei
still uses "svn-trunk" for his admission, dunno others), I thought I'd re-start
a thread about branch renaming with a new proposal, which is now even SHORTER !
How would you like "dev" for the main development branch ?  It'd be:
  - 1 letter shorter than "main"
  - 3 letters shorter than "master"
  - very cool ! 😎
  - clear
  - uncrowded, so nobody feels the need to run the other way
[1] https://lists.osgeo.org/pipermail/postgis-devel/2021-January/028778.html
[2] https://lists.osgeo.org/pipermail/postgis-devel/2021-June/028983.html
[3] https://lists.osgeo.org/pipermail/postgis-devel/2021-January/028781.html
So, what do you think ? Can we turn more plusses than minuses ?
--strk;
On Wed, Jan 13, 2021 at 05:38:06PM -0500, Regina Obe wrote:
> > On Thu, Jan 14, 2021 at 01:18:20AM +0300, Darafei "Kom?pa" Praliaskouski
> > wrote:
> > > Hey, the point of the thing is not to add a thing called "main" but to
> > > get rid ot the thing called "master" which your plan fails to
> > > accomplish. If we go there, go all-in.
> > I know what's the plan, but "go all-in" takes time.
> > I'm just offering a way to keep things working in the meanwhile.
> > --strk;
> I'm a -0 for any change at all.
> But if we are forced into this change I do like the idea of having a soft - main launch over a no-turning back main.
> I'd like to see other projects make the strong-move before we bother.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
  Libre GIS consultant/developer 🎺
  https://strk.kbt.io/services.html
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20251128/62988d96/attachment.sig>
