Rename "master" branch to "dev" ?
Laurențiu Nicola
lnicola at dend.ro
Fri Nov 28 12:23:47 PST 2025
-0 I didn't want to start this
On Fri, Nov 28, 2025, at 21:46, Sandro Santilli wrote:
> In IRC/Matrix we got back to discuss branch naming, due to
> CI still having traces of "main" which has been an alias at some point [1]
> As the last attempt at getting rid of the "master" name was stuck [2]
> due to Regina wanting to see other projects make the strong-move
> before bothering [3] and given today nobody would really be using "master"
> anymore while some of us use different names (I use "main" locally, Darafei
> still uses "svn-trunk" for his admission, dunno others), I thought I'd re-start
> a thread about branch renaming with a new proposal, which is now even SHORTER !
> How would you like "dev" for the main development branch ? It'd be:
> - 1 letter shorter than "main"
> - 3 letters shorter than "master"
> - very cool ! 😎
> - clear
> - uncrowded, so nobody feels the need to run the other way
> [1] https://lists.osgeo.org/pipermail/postgis-devel/2021-January/028778.html
> [2] https://lists.osgeo.org/pipermail/postgis-devel/2021-June/028983.html
> [3] https://lists.osgeo.org/pipermail/postgis-devel/2021-January/028781.html
> So, what do you think ? Can we turn more plusses than minuses ?
> --strk;
> On Wed, Jan 13, 2021 at 05:38:06PM -0500, Regina Obe wrote:
>> > On Thu, Jan 14, 2021 at 01:18:20AM +0300, Darafei "Kom?pa" Praliaskouski
>> > wrote:
>> > > Hey, the point of the thing is not to add a thing called "main" but to
>> > > get rid ot the thing called "master" which your plan fails to
>> > > accomplish. If we go there, go all-in.
>> > I know what's the plan, but "go all-in" takes time.
>> > I'm just offering a way to keep things working in the meanwhile.
>> > --strk;
>> I'm a -0 for any change at all.
>> But if we are forced into this change I do like the idea of having a soft - main launch over a no-turning back main.
>> I'd like to see other projects make the strong-move before we bother.
>> Thanks,
>> Regina
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
> Libre GIS consultant/developer 🎺
> https://strk.kbt.io/services.html
> * signature.asc
