Collaboration Interest: AI Guidance for PostGIS in pg-aiguide
Darafei "Komяpa" Praliaskouski me at komzpa.net
Sat Nov 29 15:34:46 PST 2025
I've compiled this list from all my notes, leaving only PostGIS (and a
bit of broader SQL) related things here.
https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/SKILL.md
Probably some more will surface once people start using these,
contributions are welcome :)
On Wed, Nov 26, 2025 at 2:10 PM Mat Arye <mat+postgis at tigerdata.com> wrote:
> Hey,
> This sounds great. If the SKILL.md file is maintained in the postgis
> repository, it would be easy for us to include it in pg-aiguide as well.
> Happy to share our best practices on a call or review/give feedback on a PR
> if any of that would be helpful.
> Thanks,
> Mat
> On Tue, Nov 25, 2025 at 9:01 PM Darafei "Komяpa" Praliaskouski <
> me at komzpa.net> wrote:
>> Hi,
>> Sounds good. I guess we're at a time when everyone tries to collect their
>> own library for AGENTS.md :)
>> A list of things we put together for Kontur's systems, fixing stuff
>> actually done wrong by LLMs one at a time:
>> https://github.com/konturio/AGENTS.md/blob/main/AGENTS.raw.md
>> What I also learned is that while LLM is randomly forgetful about these
>> spaced repetition helps keep the model's attention on them.
>> For small lists like ours I made a simple trigram based one,
>> https://github.com/konturio/AGENTS.md/blob/main/scripts/spaced_repetition.py
>> LLMs write okay-ish PostGIS SQL. Where they currently totally break is
>> h3, as the library changed all the function names
>> on v3 to v4 migration, and there are subtle name differences across
>> different versions. A skill will be more helpful there.
>> Maybe we can start SKILL.md in postgis repo so that whoever wants to drop
>> it into their AI and generate less-wrong, more-blessed code with typical
>> user error types corrected?
>> We're already building a cheatsheet but some common mistakes can be
>> listed to un-learn them at LLMs.
>> I'll be happy to start and maintain this doc, I'm already doing this
>> anyway for my use cases.
>> On Tue, Nov 25, 2025 at 9:50 PM Mat Arye <mat+postgis at tigerdata.com>
>> wrote:
>>> Hi All,
>>> We've started a new open-source project at Tiger Data aimed at helping
>>> AI agents generate higher-quality Postgres code:
>>> https://github.com/timescale/pg-aiguide
>>> For broader context, here’s the announcement blog describing the
>>> approach and motivations:
>>> https://www.tigerdata.com/blog/we-taught-ai-to-write-real-postgres-code-open-sourced-it
>>> As part of this work, we're adding guidance modules for major Postgres
>>> extensions, and PostGIS is at the top of our list. I’m reaching out to ask
>>> whether anyone from the PostGIS community would be interested in
>>> collaborating.
>>> The core idea is to provide “skills” that capture best practices, common
>>> pitfalls, and domain-specific patterns so that AI agents can make better
>>> decisions. Here is an example skill:
>>> https://github.com/timescale/pg-aiguide/blob/main/skills/design-postgres-tables/SKILL.md
>>> If there’s interest, we’d be happy to set up a call to walk through the
>>> approach and answer questions.
>>> Beyond skills, the project also includes semantic search over
>>> documentation. We currently index Postgres and TimescaleDB docs, and we
>>> plan to include the PostGIS manual as well. We can handle the processing,
>>> but wanted to check whether there’s anything unusual about the HTML manual
>>> that we should be aware of. We’d also appreciate any guidance on which
>>> versions of the manual are most important to index.
>>> Thanks for your time, and we’d welcome any feedback or involvement from
>>> the community.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20251130/c1517a30/attachment.htm>
