Weird issue in the PostgreSQL 18/ PostGIS 3.6 stack for Windows
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Oct 14 04:07:26 PDT 2025
Hi Pieter, be careful that the former PROJ_LIB environment variable was
changed to PROJ_DATA since the PROJ 9.1.0 release.
Thanks,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
On 2025-10-14 6:05 a.m., Gandalf the Gray wrote:
> Hi Regina.
> I am using the PostGIS 3.6 installer for PG 18 that was released yesterday.
> When using raster2pgsql from command line it gives me an error of
> proj.db not found, although PROJ_LIB is in environment, and correctly
> specified
> Raster gets created successfully though.
> Pieter
