upgrade from 3.5.3 to 3.6.0: ERROR: could not find function "ST_CoverageClean
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 21 10:00:26 PDT 2025
The implication is that for some reason the package you have includes an
older version of postgis-3.so than it is advertising. And yet has SQL
scripts for the latest version.
Maybe see if that bears out?
strings /usr/lib/postgresql/17/lib/postgis-3.so | grep "3.5"
Given that most packagers will have packaged 3.6 with PgSQL 18, not PgSQL
17, I can imagine a fat finger error happening potentially.
P.
On Tue, Oct 21, 2025 at 9:38 AM Justin Pryzby <pryzby at telsasoft.com> wrote:
> We got this error after applying debian OS updates:
> 2025-10-21 10:37:20 upgrade postgresql-17-postgis-3-scripts:all
> 3.5.3+dfsg-1~exp1.pgdg120+1 3.6.0+dfsg-2.pgdg13+1
> ts=# \dx postgis
> Name | Version | Schema | Description
> postgis | 3.5.3 | public | PostGIS geometry and geography spatial types
> and functions
> ts=# ALTER EXTENSION postgis UPDATE ;
> ERROR: could not find function "ST_CoverageClean" in file
> "/usr/lib/postgresql/17/lib/postgis-3.so"
> ts=# SELECT postgis_extensions_upgrade();
> NOTICE: Updating extension postgis 3.5.3
> CONTEXT: SQL statement "ALTER EXTENSION postgis UPDATE TO "ANY";ALTER
> EXTENSION postgis UPDATE TO "3.6.0""
> PL/pgSQL function postgis_extensions_upgrade(text) line 88 at EXECUTE
> ts=# SELECT * FROM pg_available_extensions WHERE name='postgis';
> name | default_version | installed_version |
> comment
> postgis | 3.6.0 | 3.5.3 | PostGIS geometry and
> geography spatial types and functions
> ts=# SELECT * FROM pg_available_extension_versions WHERE name='postgis';
> name | version | installed | superuser | trusted | relocatable |
> schema | requires | comment
> postgis | unpackaged | f | t | f | f |
> | | PostGIS geometry and geography spatial types and functions
> postgis | 3.6.0 | f | t | f | f |
> postgis | ANY | f | t | f | f |
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20251021/5dd96f88/attachment.htm>
