Dealing with topology data corruption on upgrade to 3.6.0
Regina Obe
lr at pcorp.us
Wed Oct 29 18:09:40 PDT 2025
> On Wed, Oct 15, 2025 at 03:11:00PM -0400, Regina Obe wrote:
> > > https://trac.osgeo.org/postgis/ticket/5983
> > I'm thinking of a plan that will work as follows to fix.
> > 1) roll back the catalog updates, that should fix existing installs
> > without having to restore from a huge backup
> > 2) Rename the existing domain and topogeometry type - something like
> > topogeometry_small
> > 3) Create new types (with the existing name, topogeometry, topoelement
> etc).
> > 4) Put in autocasts to topogeometry_small -> topogeometry
> I like the idea of having 2 distinct types so not enforce an on-disk growth of
> topologies that do not need large IDs.
Yah that would be ideal and would be less painful to roll-back existing to the lower integer version
as there in theory would be much fewer records that were damaged.
But there is a lot more code and testing involved for that path forward.
> > Unfortunately all this kinda breaks our rule of no new functions or
> > types in a micro, but I don't see how we have much choice here.
> I guess we could consider 3.6 dead and immediately jump on 3.7 if we don't
> want to break that rule.
That would require releasing 3.7 pretty soon though. Which might break packager rules. Not sure how many packagers have a rule that if they've already released a 3.6 for PG whatever
Only 3.6 micros can flow into that or since our .so is major versioned, it's okay to do that.
I also ran into an issue using pg_ugrade from 3.5 to 3.6 which I need to revisit to see what the error was there, cause I ended up just upgrading my old cluster to 3.6 before upgrading to the new cluster to get around the issue.
> What concerns me most is that what would fix old tables or even just old
> records could break new tables or new records. Think about the situation in
> which someone added NEW TopoGeometry objects to an existing table, after
> the upgrade. Some rows will REALLY have 64bit integers written on disk and
> some other will have 32bit integers instead. The only way we MIGHT have to
> tell what kind of data is really in what record would be to check the xmin
> attribute and compare it the the xmin of the postgis extension version record.
> --strk;
> Libre GIS consultant/developer 🎺
> https://strk.kbt.io/services.html
I'm not quite sure how to compare xmins. How do you compare them.
Like for example I can do equality check
select xmin, * FROM pg_extension WHERE xmin = 16676274;
But doing inequality does not work
SELECT xmin, * FROM pg_extension WHERE xmin > 16676274; -- ERROR: operator does not exist: xid > integer
select xmin, * FROM pg_extension WHERE xmin::bigint > 16676274; -- ERROR: cannot cast type xid to bigint
I presume that's because since xmin is stored as 32-bit it gets wrap around quite frequently so it probably gets recycled on vacuum or some such thing so a higher xmin might not guarantee a newer transaction.
Since you need to visit every record anyway, I still feel its safer to see if the record is corrupted with what we've been discussing here
Probably the fastest path to fix, not ideal, is to detect there is corruption in at least one table during topology upgrade, and include a function for users to fix the corruption and instruct them to do so and then come 3.7 put in the grand scheme topogeometry_small/ big options if we truly feel it impacts performance significantly for users.
It's a shame we can't just use numeric, we rely on sequences. Cause numeric are variably stored https://www.postgresql.org/docs/10/datatype-numeric.html so I imagine would be a better solution for people truly concerned about space.
