Collaboration Interest: AI Guidance for PostGIS in pg-aiguide
Mat Arye
mat+postgis at tigerdata.com
Mon Jan 5 04:34:11 PST 2026
Sorry for the delay, but I wanted to close the loop. We now have a PR for
a PostGIS skill based on Darafei's excellent work in pg-aiguide:
https://github.com/timescale/pg-aiguide/pull/62. (The only changes from the
upstream version are the removal of non-PostGIS-specific advice, which we
have elsewhere).
Thanks again!
-Mat
On Sun, Nov 30, 2025 at 12:35 AM Darafei "Komяpa" Praliaskouski <
me at komzpa.net> wrote:
> Hi,
> I've compiled this list from all my notes, leaving only PostGIS (and a
> bit of broader SQL) related things here.
> https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/SKILL.md
> Probably some more will surface once people start using these,
> contributions are welcome :)
> On Wed, Nov 26, 2025 at 2:10 PM Mat Arye <mat+postgis at tigerdata.com>
> wrote:
>> Hey,
>> This sounds great. If the SKILL.md file is maintained in the postgis
>> repository, it would be easy for us to include it in pg-aiguide as well.
>> Happy to share our best practices on a call or review/give feedback on a PR
>> if any of that would be helpful.
>> Thanks,
>> Mat
>> On Tue, Nov 25, 2025 at 9:01 PM Darafei "Komяpa" Praliaskouski <
>>> Hi,
>>> Sounds good. I guess we're at a time when everyone tries to collect
>>> their own library for AGENTS.md :)
>>> A list of things we put together for Kontur's systems, fixing stuff
>>> actually done wrong by LLMs one at a time:
>>> https://github.com/konturio/AGENTS.md/blob/main/AGENTS.raw.md
>>> What I also learned is that while LLM is randomly forgetful about these
>>> spaced repetition helps keep the model's attention on them.
>>> For small lists like ours I made a simple trigram based one,
>>> https://github.com/konturio/AGENTS.md/blob/main/scripts/spaced_repetition.py
>>> LLMs write okay-ish PostGIS SQL. Where they currently totally break is
>>> h3, as the library changed all the function names
>>> on v3 to v4 migration, and there are subtle name differences across
>>> different versions. A skill will be more helpful there.
>>> Maybe we can start SKILL.md in postgis repo so that whoever wants to
>>> drop it into their AI and generate less-wrong, more-blessed code with
>>> typical user error types corrected?
>>> We're already building a cheatsheet but some common mistakes can be
>>> listed to un-learn them at LLMs.
>>> I'll be happy to start and maintain this doc, I'm already doing this
>>> anyway for my use cases.
>>> On Tue, Nov 25, 2025 at 9:50 PM Mat Arye <mat+postgis at tigerdata.com>
>>> wrote:
>>>> Hi All,
>>>> We've started a new open-source project at Tiger Data aimed at helping
>>>> AI agents generate higher-quality Postgres code:
>>>> For broader context, here’s the announcement blog describing the
>>>> approach and motivations:
>>>> https://www.tigerdata.com/blog/we-taught-ai-to-write-real-postgres-code-open-sourced-it
>>>> As part of this work, we're adding guidance modules for major Postgres
>>>> extensions, and PostGIS is at the top of our list. I’m reaching out to ask
>>>> whether anyone from the PostGIS community would be interested in
>>>> collaborating.
>>>> The core idea is to provide “skills” that capture best practices,
>>>> common pitfalls, and domain-specific patterns so that AI agents can make
>>>> better decisions. Here is an example skill:
>>>> https://github.com/timescale/pg-aiguide/blob/main/skills/design-postgres-tables/SKILL.md
>>>> If there’s interest, we’d be happy to set up a call to walk through the
>>>> approach and answer questions.
>>>> Beyond skills, the project also includes semantic search over
>>>> documentation. We currently index Postgres and TimescaleDB docs, and we
>>>> plan to include the PostGIS manual as well. We can handle the processing,
>>>> but wanted to check whether there’s anything unusual about the HTML manual
>>>> that we should be aware of. We’d also appreciate any guidance on which
>>>> versions of the manual are most important to index.
>>>> Thanks for your time, and we’d welcome any feedback or involvement from
>>>> the community.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20260105/08bd5e65/attachment.htm>
