ST_DWithin Prepared
Paul Ramsey pramsey at cleverelephant.ca
Tue Jan 13 12:43:23 PST 2026
If you build your own PostGIS and have a workload that uses ST_DWithin, it
would be great if you'd try out the development branch (master) and see if
your workload is any faster (or slower) after this change.
https://github.com/postgis/postgis/commit/48a31d424a91b9fda7c125a5c5594689e87d562c
Prepared geometry and caching are not cost free, but hopefully any use
cases that degrade only do so a tiny bit, because the ones that get faster
get quite a bit faster.
P.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20260113/f971e8ef/attachment.htm>
