MobilityDB for PG 19
Regina Obe lr at pcorp.us
Mon Jul 20 11:37:21 PDT 2026
I haven’t gotten around to building the PG19 ones yet.
I have a repo I’m working on to catalog all my scripts but it’s still a work in progress. Eventually I’ll also provide the dependency binaries I’ve built cause that is what takes most of the time.
I’ve just pushed the mobilitydb ones.  https://gitea.osgeo.org/robe/windows_build_recipes/src/branch/main/projects/mobilitydb  but I’m going to change them soon to work against the same set of dependencies I’m building PostGIS 3.7 against which are in here - https://gitea.osgeo.org/robe/windows_build_recipes/src/branch/main/makedependenciesw64.sh
For the PG19 you’ll need to change the geos to 3.15 and proj to 9.8.1  https://gitea.osgeo.org/robe/windows_build_recipes/src/branch/main/makedependenciesw64.sh#L362
I’ll work out the script later this week if you can wait that long.
Also take a look at mobilitydb msys script - https://github.com/MobilityDB/MobilityDB/blob/master/.github/workflows/windows_msys2.yml  they use the dependencies already packaged with mingw64.
From: Gandalf the Gray <pjduplooy.gis at gmail.com>
Sent: Monday, July 20, 2026 12:19 PM
To: postgis-devel at lists.osgeo.org
Subject: MobilityDB for PG 19
Hi Regina
Is it possible that you can send me the build instructions for Windows PG19 MobilityDB?
Regards
Pieter
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20260720/467e007f/attachment.htm>
