3.6.4 Release
Greg Troxel
gdt at lexort.com
Sat Jun 6 11:06:34 PDT 2026
This is very likely not new, and I don't mean to demand that anybody fix
it, but there's a lot of UB around ctype(3) functions. The allowable
values of arugments is very narrow. POSIX says for isalpha (the rest
have the same rules):
The c argument is an int, the value of which the application shall
ensure is representable as an unsigned char or equal to the value of
the macro EOF. If the argument has any other value, the behavior is
undefined.
https://pubs.opengroup.org/onlinepubs/9799919799/functions/isalpha.html
The problem is passing "char" to one of these functions. Yes, I can
totally see why that's obviously ok -- except it isn't :-(.
The short form:
optionlist.c:36:18: warning: array subscript has type 'char' [-Wchar-subscripts]
lwin_wkt.c:91:36: warning: array subscript has type 'char' [-Wchar-subscripts]
lwalgorithm.c:697:27: warning: array subscript has type 'char' [-Wchar-subscripts]
lwgeom_box.c:68:24: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_geos_predicates.c:923:21: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_gml.c:514:17: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_gml.c:561:35: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_gml.c:565:15: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_gml.c:589:20: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_gml.c:669:17: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_gml.c:673:15: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_gml.c:809:20: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_gml.c:816:21: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_gml.c:880:17: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_gml.c:883:15: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_kml.c:332:24: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_kml.c:336:18: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_kml.c:353:30: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_kml.c:358:30: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_kml.c:359:22: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_kml.c:371:40: warning: array subscript has type ‘char’ [-Wchar-subscripts]
lwgeom_in_marc21.c:153:23: warning: array subscript has type ‘char’ [-Wchar-subscripts]
trying to trim the log to these issues:
---- Making all in liblwgeom
libtool: compile: gcc -I./../deps/ryu/.. -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include/json-c -I/usr/pkg/include -DNDEBUG -I. -I. -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -fPIC -DPIC -c optionlist.c -fPIC -DPIC -o .libs/optionlist.o
In file included from /usr/include/ctype.h:100,
from optionlist.c:28:
optionlist.c: In function 'option_list_string_to_lower':
36 | *key = tolower(*key);
libtool: compile: gcc -I./../deps/ryu/.. -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include/json-c -I/usr/pkg/include -DNDEBUG -I. -I. -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -fPIC -DPIC -c lwin_wkt.c -fPIC -DPIC -o .libs/lwin_wkt.o
from lwin_wkt.c:27:
lwin_wkt.c: In function 'wkt_dimensionality':
91 | else if( ! isspace(dimensionality[i]) ) break;
libtool: compile: gcc -I./../deps/ryu/.. -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include/json-c -I/usr/pkg/include -DNDEBUG -I. -I. -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -fPIC -DPIC -c lwalgorithm.c -fPIC -DPIC -o .libs/lwalgorithm.o
from lwalgorithm.c:28:
lwalgorithm.c: In function 'decode_geohash_bbox':
697 | char c = tolower(geohash[i]);
---- Making all in postgis
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -Dz_off_t=long -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -fPIC -DPIC -fvisibility=hidden -I../liblwgeom -I../liblwgeom -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -I../libpgcommon -I../deps/flatgeobuf -I../deps/wagyu -I../deps/uthash/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include/json-c -I/usr/pkg/include -DNDEBUG -fPIC -DPIC -I. -I./ -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -Dz_off_t=long -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include -c -o lwgeom_box.o lwgeom_box.c
from /usr/pkg/include/postgresql/server/port.h:16,
from /usr/pkg/include/postgresql/server/c.h:1385,
from /usr/pkg/include/postgresql/server/postgres.h:45,
from lwgeom_box.c:27:
lwgeom_box.c: In function ‘BOX2D_in’:
68 | str[i] = tolower(str[i]);
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -Dz_off_t=long -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -fPIC -DPIC -fvisibility=hidden -I../liblwgeom -I../liblwgeom -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -I../libpgcommon -I../deps/flatgeobuf -I../deps/wagyu -I../deps/uthash/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include/json-c -I/usr/pkg/include -DNDEBUG -fPIC -DPIC -I. -I./ -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -Dz_off_t=long -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include -c -o lwgeom_geos_predicates.o lwgeom_geos_predicates.c
from lwgeom_geos_predicates.c:31:
lwgeom_geos_predicates.c: In function ‘relate_pattern’:
923 | im[i] = toupper(im[i]);
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -Dz_off_t=long -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -fPIC -DPIC -fvisibility=hidden -I../liblwgeom -I../liblwgeom -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -I../libpgcommon -I../deps/flatgeobuf -I../deps/wagyu -I../deps/uthash/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include/json-c -I/usr/pkg/include -DNDEBUG -fPIC -DPIC -I. -I./ -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -Dz_off_t=long -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include -c -o lwgeom_in_gml.o lwgeom_in_gml.c
from lwgeom_in_gml.c:49:
lwgeom_in_gml.c: In function ‘parse_gml_srs’:
514 | if (!isdigit(*p)) gml_lwpgerror("unknown spatial reference system", 5);
lwgeom_in_gml.c: In function ‘parse_gml_double’:
561 | if (space_before) while (isspace(*d)) d++;
565 | if (isdigit(*p))
589 | else if (isspace(*p))
lwgeom_in_gml.c: In function ‘parse_gml_coordinates’:
669 | while (isspace(*p)) p++; /* Eat extra whitespaces if any */
673 | if (isdigit(*p)) digit = true; /* One state parser */
lwgeom_in_gml.c: In function ‘parse_gml_pos’:
809 | while (isspace(*pos)) pos++; /* Eat extra whitespaces if any */
816 | if (isdigit(*pos)) digit = true;
lwgeom_in_gml.c: In function ‘parse_gml_poslist’:
880 | while (isspace(*poslist)) poslist++; /* Eat extra whitespaces if any */
883 | if (isdigit(*poslist)) digit = true;
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -Dz_off_t=long -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -fPIC -DPIC -fvisibility=hidden -I../liblwgeom -I../liblwgeom -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -I../libpgcommon -I../deps/flatgeobuf -I../deps/wagyu -I../deps/uthash/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include/json-c -I/usr/pkg/include -DNDEBUG -fPIC -DPIC -I. -I./ -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -Dz_off_t=long -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include -c -o lwgeom_in_kml.o lwgeom_in_kml.c
from lwgeom_in_kml.c:40:
lwgeom_in_kml.c: In function ‘parse_kml_coordinates’:
332 | while (*p && isspace(*p)) ++p;
336 | if ( isdigit(*p) || *p == '+' || *p == '-' || *p == '.' ) {
353 | if ( *q && ! isspace(*q) && *q != ',' ) {
358 | while (*q && isspace(*q)) ++q;
359 | if ( isdigit(*q) || *q == '+' || *q == '-' || *q == '.' || ! *q ) {
371 | } else if ( *p != ',' && ! isspace(*p) ) {
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -Dz_off_t=long -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -fPIC -DPIC -fvisibility=hidden -I../liblwgeom -I../liblwgeom -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -I../libpgcommon -I../deps/flatgeobuf -I../deps/wagyu -I../deps/uthash/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include/json-c -I/usr/pkg/include -DNDEBUG -fPIC -DPIC -I. -I./ -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -Dz_off_t=long -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include -c -o lwgeom_in_marc21.o lwgeom_in_marc21.c
from lwgeom_in_marc21.c:21:
lwgeom_in_marc21.c: In function ‘is_literal_valid’:
153 | if (!isdigit(literal[j])) {
