Should agentic skill files be elsewhere ?
Sandro Santilli
strk at kbt.io
Mon Jun 8 10:59:05 PDT 2026
I noticed a skills/ directory was added, containing both postgis-specific
document and postgis-agnostic document.
The directory has no README file, but I learnt that such files are meant
to be read by AI-based coding agents, to pass them to LLM inference
tools as a "context".
My question is: do these files belong in the PostGIS code base ? I suspect no.
For comparison, the Gitea project uses a separate repository [1] for this,
I'd use the same approach.
A separate repository would have a proper README and could maybe also
have different set of skills for different scenarios, and different usage
instructions for different tools (I find it unfair that a single tool name
is referenced by these docs while there are a lot of tools out there).
So, what do you think about this ? I haven't found a thread in this list
discussing this addition, so here it is.
[1] https://gitea.com/gitea/gitea-tea-skill
Libre GIS consultant/developer 🎺
https://strk.kbt.io/services.html
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20260608/431bc202/attachment.sig>
