[postgis-tickets] [PostGIS] #2143: [raster] Width and Height column of raster_columns view may need changing
PostGIS trac at osgeo.org
Mon Dec 10 17:57:17 PST 2012
 Reporter:  dustymugs    |       Owner:  dustymugs
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  raster       |     Version:  trunk
 Keywords:               |
Comment(by dustymugs):
 You don't.  You're assuming the table is a coverage.  How about if the
 user doesn't want a coverage, namely me.  I just want a width check, which
 has nothing to do with whether or not the tile falls perfectly in a
 coverage's grid.
 Therefore, you have to have a separate constraint.  A width constraint is
 just that, a width constraint.  Same goes with height.  A coverage tile
 constraint ensures that the width and height are correct because the tile
 having the correct width and height is critical to be part of a coverage.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2143#comment:8>
