[postgis-tickets] [PostGIS] #2146: ST_AsText returns 'e' as exponent
PostGIS trac at osgeo.org
Tue Dec 11 21:03:43 PST 2012
  Reporter:  yossi    |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.3
 Component:  postgis  |     Version:  2.0.x
Resolution:  invalid  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 I'm going to dismiss this as an invalid request.  If your issue is that it
 should be E because that is the standard for PostgreSQL, then I would have
 to point out this.
 SELECT POWER(10,-20);
 Which on my windows box returns:
 1e-020
 lowercase e.  So I see no reason why the output from PostGIS should be
 upper case E when said function returns lowercase e.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2146#comment:3>
