[postgis-tickets] [PostGIS] #1987: Results given by ST_Simplify inconsistent between PostGIS 1.5.2 and 2.0.1
PostGIS trac at osgeo.org
Wed Dec 12 18:05:25 PST 2012
  Reporter:  ChrisInCambo  |       Owner:  pramsey
      Type:  defect        |      Status:  closed
  Priority:  blocker       |   Milestone:  PostGIS 2.0.2
 Component:  postgis       |     Version:  2.0.x
Resolution:  fixed         |    Keywords:  history
Comment(by robe):
 +1 works for me.  I'm even fine with if we revert back to the old 2.0.1
 but have some legacy function install for the old behavior.  With a note
 in the docs for those who badly need the old 1.5 to hack their system with
 it. We do that for the gist index naming issue already. It's too bad we
 don't have a legacy mode like some other systems e.g. SQL Server where you
 can turn on a bit and say use old 2005/2008 behavior.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1987#comment:29>
