[postgis-tickets] [PostGIS] #1987: Results given by ST_Simplify inconsistent between PostGIS 1.5.2 and 2.0.1
trac at osgeo.org
Thu Dec 13 00:16:40 PST 2012
Reporter: ChrisInCambo | Owner: pramsey
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Resolution: fixed | Keywords: history
Comment(by strk):
robe: we _might_ have a "legacy mode" (or bigger set of params) as a GUC.
{{{SET postgis_simplify_collapses_as_null TRUE}} kind of thing.
Or I could add an st_simplify_nullifcollapsed for a legacy, is that what
you had in mind ?
Chris: 2.0.2 restored 1.5.x behavior, but I keep thinking that behavior is
suboptimal because it destroys information that could be destroyed by a
subsequent function (ie: drop areas smaller than X). I think the most help
you can give is by providing us the data that was giving you problem, to
better analyze what the problem was.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1987#comment:31>
