[postgis-tickets] [PostGIS] #2147: error when updating postgis_topology extension
trac at osgeo.org
Thu Dec 13 07:36:24 PST 2012
Reporter: kyngchaos | Owner: robe
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.3
Component: build/upgrade/install | Version: 2.0.x
Keywords: |
Comment(by kyngchaos):
Hmm, I was going to try a quick patch myself so I can package a fixed OS X
installer, and I see that the postgis extension update script has some
non-POSIX sed REs also. But Postgres didn't complain about this one, the
postgis extension update ran without error:
sql_bits/postgis_upgrade_minor.sql:
../../postgis/postgis_upgrade_20_minor.sql
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' \
-e '/^\(DROP\|CREATE\) \(CAST\).*;/d' \
for (one example):
DROP CAST IF EXISTS (geometry AS geometry);
CREATE CAST (geometry AS geometry) WITH FUNCTION geometry(geometry,
integer, boolean) AS IMPLICIT;
probably because it's dropping the cast before creating it.
This one uses sed to strip them out in both the extension and non-
extension update scripts.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2147#comment:10>
