[postgis-tickets] [PostGIS] #2151: LDFLAGS from rpm spec file is overwritten when creating the postgis-2.0.so
trac at osgeo.org
Fri Dec 14 11:38:26 PST 2012
Reporter: xchinu | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.3
Component: postgis | Version: 2.0.x
Keywords: |
Issue:
I have postgresql-devel-9.2.2 package installed before I try to create an
RPM package for the postgis-2.0.2; I updated the postgis-2.0.2 rpm spec
file with an LDFLAGS that has -Wl,-rpath set to libgoes_c.so.1 and
libjosn.so.0 amongst few others. But the postgis-2.0.so created does not
have the RPATH.
Analysis:
During the rpm build process the postgis/Makefile is including:
/lib/pgsql/pgxs/src/makefiles/pgxs.mk which in turn includes:
/lib/pgsql/pgxs/src/Makefile.global and
/lib/pgsql/pgxs/src/Makefile.shlib and
/lib/pgsql/pgxs/src/Makefile.port
lib/pgsql/pgxs/src/Makefile.global is the one which is overriding LDFLAGS
with the following snippets:
225 ifdef PGXS
226 LDFLAGS = -L$(libdir)
227 else
228 LDFLAGS = -L$(top_builddir)/src/port
229 endif
230 LDFLAGS += -L... # all library locations required for postgresql build
and it DOES NOT include geos or json.
351 rpathdir = $(libdir)
352
353 ifeq ($(enable_rpath), yes)
354 LDFLAGS += $(rpath)
355 endif
Probably the postgresql-9.2.2 needs a patch to fix not overriding LDFLAGS.
But postgresql build process appends the LDFLAGS present in the postgresql
spec file and works fine.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2151>
