[postgis-tickets] [PostGIS] #2152: Buildbot test 8.4 for 2.0 branch
trac at osgeo.org
Sun Dec 16 13:09:38 PST 2012
Reporter: robe | Owner: robe
Type: task | Status: closed
Priority: medium | Milestone: PostGIS 2.0.3
Component: buildbots | Version: 2.0.x
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Doen to test 8.4, 9.0 and changed from testing GEOS 3.4 to 3.3.7 dev
So 2.0 branch runs regress:
Regress 9.0, 8.4
3.3.7dev
GDAL 2.0 dev
I'm thinking of switching to test GDAL 1.9 dev branch, but winnie tests
that branch already anyway. I'm not sure if its worth effort to test 9.1,
9.2 as it will slow down the build a bit and since more people are running
those will more likely to catch. Unless we just do those tests daily as a
spot check.
Might not be a bad idea to do a more regressive off-peak spot check of the
various combinations of libraries. Like testing libxml versions.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2152#comment:1>
