[postgis-tickets] [PostGIS] #2089: liblwgeom cannot be used through python ctypes
trac at osgeo.org
Mon Dec 17 23:46:11 PST 2012
Reporter: brushtyler | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: liblwgeom | Version: trunk
Keywords: |
Comment(by strk):
brushtyler: do you have raster support build enabled ?
cu_tester.c:243:6: warning: no previous prototype for
‘lwgeom_init_allocators’ [-Wmissing-prototypes]
cu_tester.c: In function ‘lwgeom_init_allocators’:
cu_tester.c:244:2: error: ‘lwalloc_var’ undeclared (first use in this
function)
cu_tester.c:244:2: note: each undeclared identifier is reported only once
for each function it appears in
cu_tester.c:245:2: error: ‘lwrealloc_var’ undeclared (first use in this
function)
cu_tester.c:246:2: error: ‘lwfree_var’ undeclared (first use in this
function)
cu_tester.c:247:2: error: ‘lwnotice_var’ undeclared (first use in this
function)
cu_tester.c:248:2: error: ‘lwerror_var’ undeclared (first use in this
function)
make[3]: *** [cu_tester.o] Error 1
I'll wait for the pull request
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2089#comment:19>
