[postgis-tickets] [PostGIS] #2157: Redo ST_ConcaveHull utilizing Delaunay Triangulation
trac at osgeo.org
Sat Dec 22 12:20:14 PST 2012
Reporter: robe | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
Description changed by robe:
Old description:
> At the time I wrote ST_ConcaveHull, we didn't have ST_DelaunayTriangles
> so its much less efficient than it should be.
> http://www.postgis.org/documentation/manual-svn/ST_DelaunayTriangles.html
> The next version I was hoping to incorporate that logic, but that may
> require I have two versions since some people feel we need to support
> many versions of GEOS for each instance of PostGIS and I can't therefore
> require GEOS 3.4.0 without breaking backward compatiblity for some folks
> who are unfortunate enough to run 2.1 with anything less than GEOS 3.3.
> Next iteration, I'm planning to follow the other Sandro's approach as
> noted here:
> https://www.gaia-gis.it/fossil/libspatialite/wiki?name=tesselations-4.0
> As a side note - it would be nice if we had all those tessslation
> functions that Spatialite has as well since they are a common step in
> many workprocesses.
New description:
At the time I wrote ST_ConcaveHull, we didn't have ST_DelaunayTriangles so
require I have two versions since some people feel we need to support many
who are unfortunate enough to run 2.1 with anything less than GEOS 3.4.
noted here:
functions that Spatialite has as well since they are a common step in many
workprocesses.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2157#comment:2>
