[postgis-tickets] [PostGIS] #2089: liblwgeom cannot be used through python ctypes
PostGIS trac at osgeo.org
Thu Dec 27 03:28:07 PST 2012
 Reporter:  brushtyler   |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  liblwgeom    |     Version:  trunk
 Keywords:               |
Comment(by strk):
 a few more issues:
  1. Do not add an rt_module.c file, the only file in rasterland dealing
 with postgresql should be rt_pg.c
  2. Reduce the changes to the least possible files. In particular try to
 avoid modifying header files unless strictly necessary. I think neither
 cu_tester.h nor rt_pg.h nor lwgeom_pg.h need any change (the
 _init_allocators functions could be module-statics)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2089#comment:24>
