[postgis-tickets] [PostGIS] #2556: ST_Intersects results depending on insert order
trac at osgeo.org
Tue Dec 3 10:59:31 PST 2013
Reporter: gekorob | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.2
Component: postgis | Version: 2.1.x
Keywords: st_intersects intersection geography |
Comment(by pramsey):
Thank you for the complete and easily replicable ticket. Confirmed,
something is amiss. (OSX, pgsql 9.3, postgis 2.1). You note your 2.0
postgis provides correct (though slower) results?
For future reference, when you see order-dependence in results usually
you're seeing something wrong in the geometry caching system. The uncached
initial results and cached secondary results are disagreeing. In your
case, there's something *else* going on, since curiously both the brute
force and the tree results agree, but the cached result does not.
ST_Intersects is actually just a synonym for distance == 0, and the
algorithms are shared between the two operations, so the first thing I
always do when I get a report like this is compare the distance results
for various ways of running the query:
select id, name, st_distance(extent,
st_geogfromtext('SRID=4326;POLYGON((-46.625977 81.634149,-46.625977
81.348076,-48.999023 81.348076,-48.999023 81.634149,-46.625977
81.634149))')) from images;
select id, name, _st_distancetree(extent,
select id, name, _ST_DistanceUnCached(extent,
Usually I find a distance between the two algorithms, the tree and the
uncached brute force. In this case, the difference is between the wrapped
cache function and the others. This will take some effort to debug, which
won't happen for a while as I have other paid work at the moment.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2556#comment:1>
