[postgis-tickets] [PostGIS] #2557: [raster]: ST_MapAlgebra doco page needs lots of work
trac at osgeo.org
Tue Dec 3 22:49:47 PST 2013
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.2
Component: documentation | Version: 2.1.x
Keywords: |
In reading thru:
http://postgis.net/docs/manual-dev/RT_ST_MapAlgebra.html
The page is very inconsistent.
1) It presents a callbackfunction example which uses the keyword position
(unquoted).
2) The callbackfunction says the position should be 2-dimensions
position integer[][]
but then later it says
position integer[]
3) The last example of Variant 1 is borken - has an invalid CTE and
probalby invalid other things as well like use of a non-existent call back
function that doesn't even agree with the definition of what the call back
function is described to contain.
My guess is this page wasn't fully done to confirm to whent eh regproc
signature changed to support both ngb and non-ngb map algebra callback
functions
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2557>
