[postgis-tickets] [PostGIS] #2560: view xxx depends on function st_union(geometry)
PostGIS trac at osgeo.org
Mon Dec 9 07:51:44 PST 2013
 Reporter:  strk                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
 I got striked by this known issue of aggregates upgrade being impossible
 to do in-place (ie: without a drop).
 Should we provide an automatic solution to the problem ?
 For example, could we drop all views using any postgis function during
 upgrade and re-create them later ? Or is there any other known workaround
 to the problem that you are aware of ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2560>
