[postgis-tickets] [PostGIS] #2561: Make sure postgis_full_version() detects mis-sync between core and raster
PostGIS trac at osgeo.org
Mon Dec 9 09:43:58 PST 2013
 Reporter:  strk                   |       Owner:  strk
     Type:  task                   |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
 After manually fixing a problem wit postgis (core) upgrade, I was
 surprised that "postgis_full_version()" did not complain about scripts/lib
 versioning mismatch while still telling me that RASTER was activated. I
 haven't checked, but was thinking we should carefully check if you'd get
 any warning when RASTER is consistently in one version (both lib and
 scripts) and CORE is consistently in another version (both lib and
 scripts).
 I'd think we should be nice and tell the user about that, but I suspect
 that's not the case, so this ticket is a task ticket to verify.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2561>
