[postgis-tickets] [PostGIS] #2485: [raster]: raster constraints prevent raster data from restoring
trac at osgeo.org
Mon Dec 16 05:50:48 PST 2013
Reporter: rdunklau | Owner: dustymugs
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.5
Component: raster | Version: trunk
Keywords: |
Comment(by robe):
rdunklau,
I agree the documentation should be updated regardless. I have on my todo
to do that much (since even if we fix people running lower versions should
know about it so they can upgrade). I was hoping I wouldn't have something
really complicated that people need to do to work around the issue (or
worse yet say tough luck). Installing in pg_catalog seems like the least
painful of options (but as mentioned with the downside you can't go back).
If we fix, I doubt we'll be pushing the fix to 2.0 unless its an easy fix.
So more like 2.1/2.2.
Bborie -- any more thoughts?
Thanks,
Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2485#comment:28>
