[postgis-tickets] [PostGIS] #2580: postgis should only be allowed to be installed only once per database
trac at osgeo.org
Wed Dec 18 07:22:49 PST 2013
Reporter: ardell | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.2
Component: postgis | Version: 2.1.x
Keywords: |
Description changed by robe:
Old description:
> See IRC transcript below...
> ardell
> i'm trying to use st_simplify, but I think something is wrong with the
> geometry type I'm passing in (postgis.geometry vs geometry)...
> select st_simplify(polygon, 1.0) from areas where title='90210';
> ERROR: function st_simplify(postgis.geometry, numeric) does not exist
> LINE 1: select st_simplify(polygon, 1.0) from areas where title='902...
> HINT: No function matches the given name and argument types. You might
> need to add explicit type casts.
> any ideas?
> strk
> select postgis_full_version();
> ardell
> -[ RECORD 1
> postgis_full_version | POSTGIS="2.1.1 r12113" GEOS="3.4.2-CAPI-1.8.2
> r3921" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.10.1, released
> 2013/08/26" LIBXML="2.9.1" LIBJSON="UNKNOWN" TOPOLOGY RASTER
> strk
> select proname, proargnames from pg_proc where proname = 'st_simplify';
> select proname, proargnames, proargtypes from pg_proc where proname =
> 'st_simplify';
> ardell
> 'st_simplify';
> proname | proargnames | proargtypes
> st_simplify | | 223484 701
> st_simplify | | 258173 701
> st_simplify | {tg,tolerance} | 259492 701
> tg = topogeometry?
> strk
> select oid, typname from pg_type where oid in (701,223484,258173,259492);
> you should have only 2 in a new install
> ardell
> oid | typname
> 701 | float8
> 223484 | geometry
> 258173 | geometry
> 259492 | topogeometry
> strk
> one of the two you have with no proargnames should go away
> select n.nspname, t.typname from pg_type t, pg_namespace n where n.oid =
> t.typnamespace and t.typname = 'geometry';
> ardell
> nspname | typname
> public | geometry
> postgis | geometry
> strk
> mess
> how was that built ?
> how could we help avoiding that ?
> and (what matters to you most): how can you clean that up ?
> did you install from extension ?
> ardell
> homebrew… although I later followed the instructions here
> (http://postgis.net/docs/postgis_installation.html) to CREATE EXTENSION…
> which may have already been done for me
> sigq
> Title: Chapter?2.?PostGIS Installation (at postgis.net)
> strk
> extension is harmful
> ardell
> ohhh
> strk
> personal opinion, don't take for truth
> ardell
> what would you recommend instead? the old-fashioned instructions?
> strk
> test: create db, install old way, create extension
> ardell
> createlang plpgsql yourdatabase...
> strk
> yeah
> but it's too late !
> do you have data in that db ?
> ardell
> it's a dev box i can trash the install
> strk
> can you run the test above ?
> 1) install old way
> 2) create extension postgis
> does that re-create the mess ?
> ardell
> sure i can try that, will take some time
> strk
> I just did
> robe2
> if you always install with extensions, you can't install postgis twice
> (even if in different schemas)
> strk
> no, it doesn't work
> ttt=# create extension postgis;
> ERROR: type "spheroid" already exists
> so that's not how the mess was created
> robe2
> with old way you could conceivably install in many schemas
> strk
> I'll try the other way around then
> nope, can't mess up with that either
> robe2
> strk: you could recreate the mess by install old way in public
> strk
> [strk at cdb:/usr/src/postgis/postgis(svn-trunk)] psql ttt -f
> postgis/postgis.sql --set ON_ERROR_STOP=1
> psql:postgis/postgis.sql:80: ERROR: type "spheroid" already exists
> robe2
> create extensions postgis schema postgis
> strk
> ttt=# create extension postgis schema postgis;
> ERROR: schema "postgis" does not exist
> CREATE EXTENSION
> robe2
> strk you have to create the schema first
> strk
> bingo!
> alright, so robe2, how can we help avoiding this ?
> should postgis_full_version() check that ?
> robe2
> I've noticed a lot of tools - e.g. django and ruby seem to standardize on
> installing postgis in schema postgis
> strk
> check if more than a single "postgis_full_version" function exists
> and warn about that, reporting schema names
> robe2
> strk: get rid of the old way
> strk
> nah
> no way
> robe2
> strk: for example if people can only install using extensions then they
> can't do: CREATE EXTENSION postgis; CREATE EXTENSION postgis schema
> postgis;
> strk
> it's the only one I trust, the only one that lets you install in a
> foreign system, where you don't control the install paths
> robe2
> because the extension is already registered first time
> strk
> if people can only install using extensions PostGIS would become unusable
> for somebody
> and untestable pre-install
> robe2
> strk: agreed but I think for new people its safer to push them to
> extensions
> nhv
> can't you check to see if postgis is installed already and refuse to
> install it twice
> albertid left the room (quit: Remote host closed the connection).
> strk
> nhv: right
> likes nhv way of thinking
> robe2
> for experienced people like you you have more advanced needs, and well
> you are smart enough not to screw yourself we hope
> strk
> so we need
> 1) a ticket
> 2) an enhanced postgis_full_version() to detect duplicated installs
> 3) protection against duplicated install
New description:
It is currently possible to install PostGIS twice if installed in separate
schemas. This is more of an issue if people use the old way (install in
public schema for example ) and then try to install with CREATE EXTENSION
in a non-public schema. never an issue with a pure CREATE EXTENSION since
CREATE EXTENSION postgis can only be run once per database regardless of
schema it is installed in.
ardell
any ideas?
strk
ardell
-[ RECORD 1
strk
'st_simplify';
ardell
'st_simplify';
tg = topogeometry?
strk
ardell
oid | typname
701 | float8
223484 | geometry
258173 | geometry
strk
ardell
nspname | typname
public | geometry
postgis | geometry
strk
mess
ardell
sigq
strk
ardell
ohhh
strk
ardell
strk
ardell
strk
yeah
but it's too late !
ardell
strk
1) install old way
ardell
strk
I just did
robe2
strk
no, it doesn't work
robe2
strk
robe2
strk
robe2
strk
CREATE EXTENSION
robe2
strk
bingo!
robe2
strk
robe2
strk
nah
no way
robe2
postgis;
strk
it's the only one I trust, the only one that lets you install in a foreign
robe2
strk
for somebody
robe2
extensions
nhv
install it twice
strk
nhv: right
robe2
for experienced people like you you have more advanced needs, and well you
strk
so we need
1) a ticket
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2580#comment:2>
