[postgis-tickets] [PostGIS] #2592: AddNode(atopology, apoint) redundant
trac at osgeo.org
Tue Dec 31 16:02:41 PST 2013
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.2.0
Component: topology | Version: 2.1.x
Keywords: |
In looking at functions that aren't documented, I noticed we have
topology.addnode(atopology character varying, apoint geometry)
The reason it isn't documented is our docs say
topology.addnode(atopology character varying, apoint geometry,
allowedgesplitting boolean DEFAULT false, setcontainingface boolean
DEFAULT false)
but the actual implementation is
allowedgesplitting boolean, setcontainingface boolean DEFAULT false)
We should probably clean this up in 2.2. Probably not worthwhile to fix
in 2.1/2.0. In the end it will be the same, just one less function.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2592>
