[postgis-tickets] [PostGIS] #2172: Attempt to add antarctica main body twice fails second time
trac at osgeo.org
Tue Jan 15 01:17:55 PST 2013
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.3
Component: topology | Version: 2.0.x
Keywords: |
Comment(by strk):
So, one of the "shaking" operations that happen in this case is that the
line, which is a _closed_ line, gets rotated to start at the leftmost
vertex, due to union, difference, intersection operations performed.
After that we are left with _two_ edges to add, because the original first
point was added as a node in the first insertion and now ends up splitting
the geometry.
This occurrence isn't supposed to result in a problem later, but it's
worth pointing out that the effect of it is that of inserting two edges
rather than a single one, so not the same as adding the identical thing
twice.
An effort could be made to reduce the shaking in these cases, but would
still not fix the bug resulting from adding those two new edges (splitted
on leftmost vertex).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2172#comment:1>
