[postgis-tickets] [PostGIS] #2179: ST_MakeValid support for NaN values.
trac at osgeo.org
Thu Jan 17 05:01:46 PST 2013
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.3
Component: postgis | Version: 2.0.x
Keywords: |
It's not easy to obtain a polygon with NaN ordinate values so here is one:
01060000000100000001030000000100000007000000010000000000F87F9CDFD01E32095341010000000000F87F193B6F0A30095341010000000000F87FA10FBF4C1D095341010000000000F87F38E258111C095341010000000000F87F5196BAFF17095341010000000000F87F4F0550911B095341010000000000F87F9CDFD01E32095341
The above geometry was found in a shapefile, and can be imported
successfully by both shp2pgsql and ogr2ogr.
ST_MakeValid not only fails at turning it into a valid, but also throws an
exception.
Possible better things to do:
1. Pretend all NaN values are an arbitrary value (0.0) ?
2. Drop all Coordinates with any NaN ordinate value (including Z and M?)
3. Return null
4. Return the input untouched
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2179>
